Is it possible to change the source on a fader but not the PreAmp? For instance, if I want to move the acoustic guitar from A-1 to C-3, but I want to keep the PreAmp settings in tact. The reason I’m asking is because I want to move a whole block of channels but I’m trying not to have to remember preamp settings for everything.
Thanks for your help.
Brent
- copy the original channel, paste it to the new fader ie. copy a1, paste to c3
-or-
- select the “new fader” channel, make its input the original channel ie. select c3, go to preamp, make the source a1
Make sure the new channel is routed to the desired destination, check dca routing, etc.
-Tim T
Thanks for the reply. However, I must clarify.
I do not wish to change the fader. I just want to change the source on the fader without it changing the preamp.
What comes to my mind would be to save your eq settings in a “user library file” for each channel you are working with.
Then make your block pre-amp changes.
After that, for each channel, recall the library file you created earlier. Make sure you select “recall pre-amp” from the recall screen as the default recall mode ignores pre-amp level.
That should accomplish what you are looking for.
Sent from my SCH-R970 using Tapatalk
