Change UI for Parallel compression
Today we have two parameters: The dry and the wet level. This is kind of awkward, because it is not easy to change the ratio between dry and wet while keeping overall level for comparison.
It would be more easy to have a single “Mix” Parameter to change the ratio between dry and wet with keeping overall level constant.
So my suggestion is: replace dry/wet level controls for parallel compression with a “mix” parameter.
Best Regards,
Tobias
+1
+1
