Aside from chrome knobs, what else changed when the Qu range upgraded to the Chrome version?
Nothing.
Perhaps not pertinent, but I believe the 1.9 firmware update happened about the same time.
@jakethepeg - Hi Jake, Qu Chrome introduced the chrome pot and fader caps from GLD for higher contrast controls in low light operation and firmware version 1.80 ‘Chrome’ which included -
Automatic Mic Mixer (AMM) for conference speech control
Mix mode for Stereo Groups for more monitor sends (Qu-24/32/Pac)
Spectrogram
Admin user password now affects Qu-Pad app login
Qu-You user password set at the mixer for Qu-You app login
Audio setup, AMM, linking, routing and matrix functions added to the Qu-Pad app
High Pass Filter (HPF) slope increased from 12 to 18dB/octave
Reset default for Scene Global Filter now blocks Custom Layer and SoftKey settings
LR routing function assignable to the Qu-Pac Qu-Control screen
Qu-Pac reset default for CH17-32 source is dSNAKE 1-16
Otherwise, no internal hardware changes were made.
Hope this helps.
Cheers.
Harry.
Thanks, Harry, for the clarification and other details. The firmware update was 1.8, not 1.9. I’m old, and my memory is somewhat faulty!
Thanks for all of the responses. That clarifies it!
So if i update firmware from v1.73 to 1.9 will i have all the goodies u just mentioned jake
Yes. If you use Qu-Pad you’ll need to make sure it’s firmware 1.9x as well.
