Changing PEQ with softkeys/actions
Is there a way to control the gain of a certain eq band of the peq on a channel? I’ve been able to toggle the bypass but was wondering if I could increase the gain of a specific band via actions. I’m using this as a bass boost as we don’t have any subs in our system that I can route directly to and there’s some songs that I would like to feel it a bit more, or if there’s a better way to do this that would also be great.
Maybe alternatively you could set up a second channel of this input that contains only the boost in the desired bass range, and whose fader you can then add as needed.
And you could also mute this “bass channel” if necessary - also via softkey.
This could work, I assume you mean I just low pass all the highs I don’t want then boost the eq?
Yes, something like that I was thinking.
Basically just a bandpass with the paramters you were planning to boost anyway.
All other frequencies would have to be cut.
Are you using any FX on the original channel?
