Changing the default MIX button
I’m using my GLD in a unique theatre setup and have 4 separate PA speakers. I’ve set it up so that each speaker is being fed by a separate group, but all with the same mix. I want them separate so I have independent volume control.
I’m wondering if there is a way to change the default or ‘go-to’ MIX key (normally it’s the main mix). Right now I have a soft key setup as a mix button, but I’d like it to revert back without using the soft key, if that’s possible.
Thanks! [8D]
Couldn’t you just use matrix outputs instead? Feed each matrix output from the main mix and problem sorted as the main mix default will work for you!
Cheers
Richard Howey
Audio Dynamite Ltd
Thanks! That’ll work great!
I keep forgetting about how versatile matrix mixes can be.
