When I recall a previously stored channel (with EQ and comp-settings) from the channel library, I would like the channel-strip display to show the name (ie: “Vocal”) of the preset i have recalled. any way to do this?
Also: when copying a channel (ie. you just want ch 3, which is labelled “Hi-Hat” to ch 5) using the copy/past button, why does not the name (label on the strip) get copied as well, or at least there should be an option…?
I think the reason for not having it copy the names by default is so that if you were setting up similar inputs with different names eg. BGV 1, BGV 2, BGV 3 you can copy settings without messing up the labelling and forgetting which is which. It makes sense for the library setting though.
In our church we have been using the GLD for 6 months and would start using the libraries to save the individual vocalist channel. In saving the name and color with the channel would make it very easy to recall from USB each vocal thus I would add my vote for this feature. [ ]
