Channel bus routing
This is a really critical feature for all applications dealing with broadcasting and conferences. A channel has to be applicable to busses or not. For that buttons are needed to take them in or out a bs or mix. Live TV interview connections or live sound multi-channel reinforcements where the speakers outputs are controlled by the Send faders can’t be done without this feature.
And the fixed layout of having linked the 7 and 8 Mixes/Outputs only for Main kills some Jobs. All 8 outputs should be optional fully independent when needed w/ channels and mixes routed to them.
The best way to implement it should be buttons on the ‘Config’ page and for sure in the ‘Sends’ pane of the channel edit window. There I would expect to find it. Very helpful on that way may be to implement 4 Groups.
Kind regards,
Uli
+1 for more flexible grouping and output routing options please :slight_smile:
Another +1
