I really would love to see the compressors made pre or post eq switchable in the signal path. The m32 and x32 have this feature and is a huge life saver when running monitors from FOH. I run my auxes pre pre and it’s essential for my channel compressor to also compressor that channel being sent to my wedges. I prefer this much more than over all compression on my mix outputs.
for each mixbus there is the possibility to set the pickup point:
- Post Preamp
- Post Insert
- Post PEQ (= Pre Compressor)
- Post Delay (= Post Compressor)
When placed in “post ins return, the conpressor does not affect the sends to the mixes from a channel. It only affects it when in “post delay”
Actually it affects in it “post eq” also. Post insert return setting for the mix output receives only the hpf gate and insert. No compressor
