Hi, i am facing a wierd automatic fader down, after i stop the sound with my qu16.
The daw starts well with sonar x3, and when i press space for lisntening the music, it feels ok, after i click stop the 2nd fader goes down, and never goes up.I have to reset the fader or tap the sonar daw up or down to set it to the last point.
Anyone with this problem?
This sounds like it may be sending a MIDI message to the desk which causes the fader to move, so I would recommend removing any MIDI IO between the desk and DAW and see if it stops this behaviour.
Didn’t work because i need that “Costum” DAW to do my mix and my Automation from MIDI Software… It seems like a glitch from the connection MIDI between the mixer and the pc…
Weird stuff…
You can start a ticket at support.allen-heath.com if you would like further assistance with this, but as we don’t officially test Sonar with DAW Control, it may be worth contacting their support department in case they know why this might happen.
I will share my experience with this software (SONAR X3). I’ve made my tests, and it stopped doing that fader problem.
I’ve shared a picture to you all. In that picture we can see my configuration when i solved the problem. The patch from the channels DAW CONTROL MIDI is very important and can make the difference.
No more problems with faders or channels and no more issues with anything.
3 Hours spent to solve this puzzle =) but its done!
