Channel insert in IO matrix
Hello,
I would like to be able to plug external devices to my SQ as inserts lets say for example an analog compressor. I’d activate the insert on my channel, then go to the IO matrix select the output insert tab and output it where i would need it. Be it local io, Slink io, addon cards io or usb io. Then i’d go into the input insert tab and select where it comes back from. Which would route the signal back to my original channel.
Well. Sorry about this post. I hadn’t updated my sq5 to the latest firmware, and now i see this feature is available. Forget about it. Thanks.
