Good morning,
I have a pretty simple question but having no time to try before the show, the only thing that came to my mind is to ask here …
I have to do the following routing:
IPCHANNEL → STEREO GROUP → MASTER L / R.
I don’t want that the channel signal goes directly to the master but has to go through the group.
In the offline App, when I go to set the IP routing to the group I can’t set the panpot to the group, despite being stereo in the general setup settings …
So the question is …: the “pan” on the app that is positioned on the L / R strip, even if it is disabled, it is still executed on the group or it will go mono, as if it were an aux mono ??
Thank you all!!
Hi Poli84,
The groups use the same level fader as the LR mix, so yes, the pan for LR is the same one for the group.
When an aux is used, you now have separate level and pan available.
Alex
Ok, thanks!!!
