For some reason channels 9 thru 16 are dead. But not consistently.
The other day I had set up for an upcoming show and all worked just fine. Yesterday I went in to do some recording for a friend of mine and channels 9 thru 16 where dead. Tried everything (I Think). Moved inputs to channel 8…fine. Moved input to channel 17…fine. Did a hard reset no change. Shut down and restarted and it was fine. Any thoughts of what could have caused this?
If the “gain knob” on the channel screen is not RED, you’re on a digital input instead of the local console input. Make sure that your inputs are all the same. I don’t know why things would change as a block, but it IS possible from the scant info given about the " problem" that no matter what the cause, the “fault” may simply be mis-assignment of input source.
Do you have either a AB168 or AR2412 stage box to try and see if the channels 9-16 work via the stage box through the mixer. That would somewhat narrow down if it is a mixer input hardware problem isolated to channels 9 - 16 or a software processing issue with those channels. Either way it doesn’t fix the problem, just an experiment to try.
