Channels with Daw
Hi
I Just bought the cq18t.
I Want to use it with Daw with vst-s.
I figured out how to use 1-18 channels sending audio from the daw to the cq.
ButI cant find out what are the other channels 19-24 for.
What can I do with them?
If I send signals from the daw on that channels seamingly nothing happens.
I cannot make the cq to receive it in any way.
Could you help me?
Hello, go to the ‘Channel Assignment’ settings and associate 17/18 with 'Out 1/2". In your “DAW” add a track and choose “17/18” as the input channel. Basically everything you send from the mixer to aux “1/2” will arrive on your DAW on the previously associated channel (17/18).
go to “st. inputs / fx” on processing button. click bt, change its source to SD (which is then input 23+24). click usb, it should say inputs sourced from 19/20.
Thank You
@BloodyCactus
I found it.
Now I can use 17-18 (st in), 19-20 (usb), 23-24 (bt) channels sending signals from the daw to the cq.
But, what about 21-22 channels?
Could you help me with this as well?
Attila
thats your max. the number just jumped 2. out 21/22 doesnt exist like that for daw.
its 22 in, 24 out.
inputs
1-16, stereo in, bt, usb = 22.
outputs
1-16, aux out 1-6, main l+r = 24
thats your 24/22.
@BloodyCactus
Thank you so much.
You made it very clear for me.
