I have a problem that whenever I attach the desk to the computer via USB I get a constant noice that sounds like a clock noise. Has anyone else experienced this and how did you fix it?
what kind of computer?
sounds like a ground problem or a sample rate mismatch
I use a collection of mac’s and the problem is the same on all of them - there is a regular tick that comes through on everything, all channels including Stereo ins from cd for example and both appears in input meters and records audibly. It does this through the USB form the QU16 and I have tried my BOSE mini-mixer and it doesn’t do this so definitely generated form the QU
While it is possible that this could be coming from the Qu, it may also be due to the connection, something else taking up bandwidth on the USB bus (the Qu will use a lot more bandwidth than the Bose), USB power settings or sample rate settings.
I’d recommend ensuring you are recording at 48kHz, trying different USB cables and ports and switching off any power saving options that might be enabled.
If you’re still having problems, please contact us using support.allen-heath.com with more details about your setup (e.g. the models of mac you have tried and the program/settings you are using to record).
Cheers,
what is the software used to record?
and wich settings did you use?
sample rate, buffer size, buffers used, latency reported from the DAW
do you use an aggregated device?
hi I am using an apple mac and I have the same issues across 3 different devices while using Logic and playing anything directly through the desk into the computer - I have to admit to not knowing the rest of the technical questions
I connect directly to the MAC via USB and have tried two different cables that both work on a different mixer
if your mixer and your DAW project won’t match in sample rate you will hear clicks…
so you have to find out at wich sample rate is your DAW recording
How do I do that - I am using Logic and have tried to find the sample rate but failing?
HELP PLEASE
you should ask a Logic guy
or consult your manual of Logic
are there any other audio devices involved?
Like @SteffenR indicated, your problem is mac/DAW related and you need to learn how to use those with usb.
Many things can cause problems so you need to know what you are doing to set things up properly.
There are large descriptions of the things you have to do with windoze to make it work right.
I would expect there are some similar ones for macs and logic.
Try reading them.
Hi and thnks for the advice - I have tried everything including re-setting my sample rates to match, everything is now at 48Khz and this has just made the electrical noises into hisses and click both more frequently i guess due to the sample rate, and slightly louder too.
I think it may well be tha there is a genuine problem with the USB board so can anyone suggest how I get the desk mended
Cheers
Robin
Hi @Angryfish (Robin),
I’ve had a search through the support system, but couldn’t find anything recent from you.
As suggested, please contact us so we can run through some troubleshooting before you send off your desk to be checked.
Please see the post above that I put up this morning re having reset matching sample rates
You are too quick to blame the Qu when there are so many other things on the PC side that are the likely cause.
You may use different macs but you used the same software.
You say you matched sample rates, but what did you do about buffer sizes and other critical parameters that can cause problems.
Have you fully scrubbed your mac to optimize it for audio use?
How do you know your security software is not interfering with the usb ?
What about social media aps that phone home all the time?
There are so many other more likely causes that you ignore in your haste to blame the Qu for the problems.
Because The repair people said it was the USB board - But thanks for the unfounded and personal criticism based on absolutely nothing - Hope others can be as useful when you have an issue
And to add it was working perfectly on alll my machines until it wasn’t so the chances of all three machines developing the same hard wired fault with no wifi turned on is extremely unlikely
I have had the QU since they were first released so it is not something I am new to either
Maybe…
…Unless they all got the same software update to the opsys or similar problem.
This has nothing to do with the Qu or your being new to it.
What you describe is a mac/software problem as I see what you have described and not a Qu problem.
You never said you did anything to fix the potential problems on the mac/software.
Until you do that I will still look to the mac/software as the problem not the Qu.
Now if you completely scrubbed the mac, deleted all security software, deleted all social media crapware, fixed the buffer sizes and did the entire list of things recommended to make your pc usable for audio then I might change my mind and look for the problem on the Qu.
Could the Qu suddenly have developed a problem. do’H! its hardware and that is certainly possible.
Like the bookie said: the battle is not always to the strong, the race not always to the swift,
but that is the way to bet.
I am still betting on the mac not the Qu as being the cause of your problems.
