Would be cool to be able to set color and name from the CQ for the extra channels, USB, BT, STs and FXs.
You actually can!
It’s a little less easy - On the Mixpad app (this doesn’t work on the touchscrenes) go to Processing and select one of the channels. Then, go to Config → Inputs and without selecting anything else you’ll see that it says Name/Colour at the bottom with the name of the channel you just selected.
Thank you MarkF, it worked fine for USB and BT but not for the FX.
Also There is no color option for DCA to my knowledge.
Correct, it isn’t possible to change the colour for FX or DCAs.
