Is there a writeup describing the Opto compressor? I pretty much understand and have used the manual types. I found a link from a previous post about the A&H person describing these but the link does not work.
Try this for starters:
https://www.uaudio.com/hardware/compressors/la-3a.html
Was commonly used on masters, vocal subgroups and individual vocals too. Sorry I don’t have a link to an A&H description.
The links are interesting and I have read up on the Opto compressors. Steffen, the effects link is great - doesn’t cover the Opto setting, but a link I didn’t have stored away yet.
Anyways, I will do some testing soon. I am installing the GLD at a church with limited audio expertise. We use the manual compressors and adjusted as needed. I am worried that they may have difficulty once I leave so I will test the Opto setting and if it sounds acceptable, I will se that and minimize settings for them to worry about. Also I will use the security settings to limit access too…
Thanks again for the help.
Bob
It’s a good “set and forget” compressor for vocal soloists and stuff like that. Transparent volume levelling compression, the only issue with it is that if something loud sends it into a lot of gain reduction (maybe a plosive from the singer) it can take a bit too long to release, you can use the sidechain filter to avoid that though.
I’d quite like to see the “16T” setting the iLive has.
Chris
