Hi, Most mixers, if not all, with integrated audio interface have common function - posibillity route computer audio to Main(or any other) Out. So how can I do that on QU-PAC? I tried it on patch in/out section, but it won’t work.
Just in case, I want to send audio from ZOOM or just windows audio (not specific DAW) to QU-PAC output, so there are probably restrictions.
On ST3 set the source as USB-B (not Q-Drive). Computer audio should then come up on the ST3 channel.
I have a similar question.
We are using a QU-32 at our church. We have a PC with a DAW on it, that is fed back to the board via USB cable.
I would like to be able to plug headphones into the QU-32 and listen to the post output from the PC/DAW.
Can you help me with this?
Thanks in advance for your help!!
PAFL ST3 should do the trick provided that you are returning a stereo mix back to the Qu from the PC.
