Confused by I/O recall with Scenes
Hi community
I’m a bit confused by the recall of patching with Scene recall and Global and Active Filters
What I’m trying to do is to simplify using my desk during recording sessions.
  • When in “Record mode” I want to take my inputs from my local and Slink expander I/O and send a Post PreAmp direct out via tie-line to USB.
  • When in “Playback mode” I want to re-route the inputs so that they take input from the USB and drop the tieline send to USB
I have saved input patch libraries for these two cases from the I/O page: one called Record and 1 called Playback and I can recall them and they work. But I have go into the I/O page and click through to them to set them and it’s a bit fiddly.
So what I thought I could do was is set up two scenes: 1 Playback and 1 Record with the applicable patching on each and recall them.
But that doesn’t work. The Patching is "safe"when I change the scenes… and remains unchanged
Can I make it change when I change the scenes? I have read the manual but I’t not working quite as I expected I guess
Any help would be much appreciated
Andy
Hi Andy,
Do you have the Preamp filter set to Block?
This includes Preamp settings of input channels and socket routing (patching).
@KeithJ A&H
Thank you very much-- as always Keith, yes you are right: I had the Preamp set to Block and having it in Allow did what I was looking for.
I must say that this is an area of the User Guide that is perhaps not quite as clear as other sections.
But I just found your session on Youtube about this topic so I will watch that this eve :slight_smile:
Sharing link here for others: https://www.youtube.com/live/aZXhh8WTxP0?si=rUrykQR-oH-ixWwj
Thanks Keith
It’s a great mixer the SQ btw :slight_smile:
Andy
