Connect ME-1 to SQ6, Avantis, DX168, DX Hub system
I’m suggesting the below system to a House of Worship and want to make sure I can connect ME-1 to the system without using the ME-U.
Mixers: Avantis (FOH), SQ6 (Broadcast)
Snakes: 3 DX168 connected to Avantis
Personal Monitor: 5 ME-1s
Option Cards: Dante cards in both mixers
Thoughts are to connect the ME-1 to a port on the DXHub. Will this work? Will I be able to see the channel names on the ME-1?
For if you want to work with the me system you better buy a gx4816 instead of 3x dx168
The gx4816 has an sample rate port for the me system.
Richard
you can use a standard Fast Ethernet switch with POE to distribute the signal after the suggested GX4816
