Connecting audio interface to SQ5
Hi guys
I’m trying to put a new AV system (as a complete beginner) together and thought I’d better put it down on paper first (see attached).
Can someone tell me if it’s possible to attach the DT168 and an iPad/audio interface (PlayAudio12) to an SQ5 via switches through Dante?
If it is, how can I bring audio from the iPad/interface into a channel strip?
I can bring audio in from the DT168.
It should be possible, but you need to do the Dante patch in Dante Controller.
I think I understand.
I see the SQ5 and DT168 on the Dante Controller but not the interface. I wonder if it has to connect directly to the iMac to register as a device or if it can just be connected to the switch ?
I can pass midi signals in the current setup to the iMac…I can change slides in ProPresenter 7…I wonder if the audio should be routed through the iMac?? ???
did you have DVS installed? is it running?
