Hi
Ive been using a iLive t112 with mixrack idr48 doing monitors from F.O.H early next year going out on tour with a separate monitor desk which will be a Yamaha M7 anyone got any ideas on the best way to connect the two together keeping it all neat and tidy.
Dave
Dave -
There is perhaps a solution with Dante, but due to the cost/complexity, I would prefer an onstage analog split. You would be assured completely independent channel processing (no preamp sharing) and if either mixer had issues, you could easily substitute any of a number of temp desks. How many channels will you require? Something like one or more of the “poor man’s splitter”
https://www.audiopile.net/products/Stagelink_snakes/Poorman_splitter_snakes/PSX-S_poorman_spliter_snakes_cutsheet.shtml
could be an inexpensive solution, or perhaps a build-it-yourself rack splitter.
Cheers,
Tim Tyler
probably will need to have at least 40 channels
Dave
If you are set in the M7, than you can use Dante, but you would need 3 Dante cards on the M7 to get all the Dante channels. It may be price prohibited.
If you go for the CL3 or CL5, it uses Dante natively and all you would need would be the Dante card on the iDr rack.
GLD-112 may be a great option. Specially if you are using Aviom or plan on getting a ME system. It would also be a cheaper option and the OS is similar enough to iLive that volunteers wouldnt be too scared.
My 2 cents
Gil
