I think he means ‘surface’ in offline mode, which makes sense. Personally I like that I know that I have contact to the mixrack, but perhaps it could be a boot process (hold down ‘x’ while booting).
The problem is that the Director software works offline like an entire system, but online it only reacts like a surface.
The signal processing is in the mixrack, which is needed for online operation. I think that’s familiar.
But you just can’t connect an offline system to an online surface (and director), that usually doesn’t make any real sense.
there are certainly very few users for the task in hand, i.e. “semi-offline”. So I’m assuming they don’t program that.
I still don’t think you understand what he is asking for. It is a task that is performed on all other consoles, and there is no good reason why you shouldn’t be able to do that on a dLive surface.
Basically, a surface is just a computer with imbedded software. There is no reason why you shouldn’t be able to pre-program a show without the mixrack connected to the surface.
Loving the director for programming shows/scenes on the couch. Would like to see some kind of signal confirmation feature to double check routing etc. Either a tone or track. Would also be helpful in learning features and presets for new users.
In offline mode this is certainly difficult to implement.
But you can be sure that the patchpoints are set when they are displayed as set.
In the upper row you can check again where the signals go or where they come from. Just click one point in the upper row and a text field will appear.
The dLive surface is just a control surface. All processing is done in the mixrack.
But I do get the implications!
The surface needs instructions from the mix-engine to do even a basic channel layout, showfiles are even kept in the CMD/DM-engine, so there would have to be a preserved place to store showfiles made on an offline console… etc
In the case of a Dlive console it will probably be more to it, but basically it’s nothing more than a midi-controller, the software isn’t inside the controller but in the computer you’re trying to control with it.
