Copy main mix levels and pan to an aux send
Copy main mix levels and pan to an aux send.
Useful feature.
It’s already possible to copy aux mixes. Why not the main mix to an aux?
+1
i also think that an option for the aux pans to follow main pans is a must have!!
aux pan follow main sometimes is needed for monitor engineers when they are working with big band in iem.
I am very glad that aux-panning has nothing to do with main-panning.
if you want to change this, there must be an appropriate choice.
I tried sq5 today. You can copy main mix to an aux mix on sq5!
This feature is address in the 1.70 firmware.
How is Aux sends available to copy? I’m just out a show with 10 IEMs. Had to move 80 channels for each send.
using the Copy / paste function and the MIX buttons.
an example:
copy the Aux1-mix:
→ press “Copy” and then together “MIX” from Aux1
copy this mix to Aux2:
→ press “Paste” and then together "Mix " from Aux2
you have copied the mix from Aux1 to Aux2
Pan-linking is also available in 1.7: Select a mix bus, go to routing, see “Follow Main Pan.”
