Copy & Paste Channel as Complete
it would be good if you could copy and paste complete channels
with all settings but also name and color or save them as a channel template complete with name etc.
I always play with the same musicians but in
different formations and numbers.
I can save the instruments and voices as a template in the library, but then I always have to spend time naming and coloring the channels in order to set up the fader bank for the evening.
Rx Thomas
Hi Thomas,
If you recall those channels using the channel library in the CONFIG screen, you will also recall their name and colour.
(when recalling using the channel library in the PROCESSING screen, you only recall the processing)
Hope this helps!
Thanks Keith, we have a GIG tomorrow night so I’ll try it.
