Copy/Paste Strip Layout
Would be nice to be able to hold copy and press a strip bank switch (a, b, c, etc.) and then hold paste and press another bank and have that strip layout copied. (if it’s an 8 fader bank to a 12 fader bank, just leave the last 4 empty.)
p.s. I love the copy/paste functionality already implemented on the board!
i second that!!
as well copiyng aux mix settings(press copy select mix on the aux) should copy pre/post settings.
Push that. Are you currently working on it? I would like the ability to RESET the banks also.
You make a good job! Thanks.
And it would be great to be able to select a group of inputs and in one operation drop them into a bank. E.g. tap the first strip and drag to select more channels. Then drag the selected channels into the bank.
Regards
Arild
@Arild G: It is called Block Select in strip assign screen, upper right corner.
@Mumu: You can copy a mix by pressing Copy + Mix on an AUX, press Paste + Mix on an AUX and all aux settings will be copied. VERY convenient feature.
@tor: but what @Mumu is asking for is that copying the mix settings of an AUX should also copy the pre/post settings. It’s time-consuming setting up a new AUX because the pre/post settings for every channel need to be checked.
In the editor, when you push the MIX button of an AUX, 2 small buttons appear below the AUX scribble strip that will make ALL POST/PRE and ALL ON/OFF. Suspect there is a similar way of doing this on the console with the PRE/POST buttons. I can’t really see how this is too much trouble :slight_smile:
On the Console to toggle ALL PRE/POST of AUX 4 you have to do the following:
  1. Press Mix of AUX 4
  2. Press and Hold PRE (between Left and Middle Fader-Bank Rotaries)
  3. Press Sel of AUX 4
Same for toggling ALL ON/OFF - simply press and hold ASSIGN and press MIX of AUX 4
Thanks @CeDoMain. I did not know that!
It would still be very useful to be able to copy the pre/post settings of one AUX to another as they aren’t typically all on or all off.
I think this is not intended like it is…
pre/post settings should be included in the mix configuration copy/paste/reset
maybe we can have a default setting for pre/post as default after reset
monitor mode > post
FOH mode > pre
