Cant find by searching the Forum…
If I copy a channel by presing copy + select of the channel und paste + select of another channel, then only EQ-Setting has been copied.
How can I copy also the Fader Positions, Special for copying a full mix of all faders from mix 3 to mix 4 eg.
Thenks for helping…
Use the Mix buttons to copy/paste levels and routing from one mix to another. Example:
copy Mix 3, paste to Mix 4
It can be found in the PDF manual under “copy, paste, reset” keys.
thanks a lot… this functions. the Settings of mix 1-4 can be copyd between eachother WITH fader positions…
but how can i copy the main mix (LR) to mix 5-6 or mix 7-8 or mix 9-10?
if i try in described way, it says in the lower Display (red letters) “cannot paste here”
the Intention is to give the inears (mix 5-6, mix 7-8, mix 9-10) the full front mix, so that i have just to regulate the chanel of the concerning singer of its taste… otherwise i have to Switch between LR and eg mix 5-6 for each channel fader to regulate one by one,… this could be better with copying all at once…
