Is there any possibility how copy actual setting of deep processing - Dyn8 - to other channel strip or save as (or create) “preset”?
Copying of Dyn8 parameters soluted.
- open Dyn8 instance on selected channel
- press copy and select opened Dyn8
- on the required strip has to be inserted next Dyn8 instance
- paste to required strip
You can press the Library button while Dyn8 is up and save that set of parameters to a Dyn8 library. You can then recall that into any other Dyn8 processor by pressing the Library button while having the Dyn8 on screen.
Disregard my last post. That is how it works on dLive, not sure if it works the same way on Avantis. I forgot which forum I was in. ![]()
Successfully discovered ![]()
- activate (open) Dyn8 instance
- press and hold options in pernament area on left side
- select Dyn8 options
- save / recall preset
