Cq-12 custom layer tab not working
So far this update was amazing just what we needed for this…but…ive installed the update 3 times now and numerous reboots with no fix…I can make custom layers and use them with the tablet but it will not work on the surface itself…I can hit and or hold the custom layer tab with no change. Just checking to see if this is a bug with the 12 or just mine…thanks
Follow exactly this:
-CONFIG button, then “Custom Layer” tab
-in the first line, click on “1” and select whatever you want to be on slot 1… repeat for slot 2 etc…
-then click on FADER button, and click top left corner on “Custom”.
-you should see the first Tab now reflecting you choice.
If that doesn’t work then yes there is an issue.
Yes no…does not work
And if you set a blank slot, does it work ?
Nope…works on tablet though
Contact support, this is not a normal behaviour.
