cq-12t allen & heath add noise on record
Absolutely clean monitoring, but noise is added to the recording. On the SD card and in DAW
the noise at the end sounds like water
added only when recording
@Dobardan
I can hear what sounds like background/street noise in the recording, maybe a car pulling away towards the end (?)
If you think there is a problem here though, and have tested with a less sensitive microphone or DI box connected (as an unterminated connection is not a good way to test!), then you can contact us directly through support.allen-heath.com and we can look at this in more detail with you.
