CQ-12T - Missing USB channels
Hello,
Firmware version is 1.1.1
Using this currently as a bit of an slightly overpowered external sound card. I have different sources from the computer and want to send back a mix of those to different locations (so a mix of my voice and music to those on discord and a mix of everything to headphones).
I can sort of manage it but for some reason I can’t get anything from the PC to the mixer through what has labelled itself as ‘CQ 7&8 (BT)’. I’ve tried enable/disable Bluetooth, fiddling with various channels with no luck. CQ 1&2 (ST) and CQ 5&6 (USB) seem to be fine.
Similar goes for audio from the mixer to the PC. CQ 1&2 (CQ12T) and CQ 3&4 (CQ12T) seem to receive audio from the mixer fine, but CQ 5&6 (CQ12T) doesnt’ seem to work no matter what I try.
Thanks in advance.
Update - I figured out to get ‘CQ 7&8 (BT)’ working as an output from PC to input ‘BT’ on the mixer in Processing → BT change the source to the USB icon.
Just need to figure out the third output from mixer to PC input.
The schematic and info I posted on another thread may be helpful to you
Thread here
