CQ-18T and Linux (Mint 21, pulseaudio, jack)
Hello,
I am a Linux geek, but I don’t have a lot of experience with audio interfaces.
I had a try with CQ-18T on Linux Mint 21.
Basically, I would say everything is working !
Please find attached dmesg and lsusb, and the CQ18T in sound preferences.
On the CQ-18T, CONFIG : Select an Input, Stereo Link, Input Source, choose USB rather than Analogue.
Then I can play any song on the computer and it goes to the CQ-18T.
Also, adding the package pulseaudio-module-jack could help.
It allows to use jack and still have sound from the computer while using Ardour for example.
When I start Ardour, I can choose Alsa (or jack) and the sound is working on each input.
Maybe linux users want to share more tips to use a CQ interface :slight_smile:
About Mixpad 1.2.0, it works under wine 9.0 (and also 9.14).
For information it didn’t work with wine 6.0.
You will need to update to wine 9.x and wine64 (amd64) is required.
Find attached my synaptic selection.
why use mixpad when you can use mixing station natively. never mess with wine if you dont have too.
use raysession to map your inputs and outputs! create virtual sinks for your mic if its not on input0 (so things like discord can see it because they only look at the very first input, stupid apps written using a browser instead of being real apps…), also create virtual sink to 18/19 then you can use that as your output easier.
I use Mixing Station too but I wanted to inform any curious user :slight_smile:
Thanks for the tips, RaySession seems very nice !
I already tried to deal with QjackCtl links but I am not confident.
Could you post a screenshot of your raysession to help my understanding ?
I’m about to go live on twitch so it has my ardour + obs on it;
virtual source input0 and input1 to to “RemappedMic_Aux0” (and 1) for anything that only sees a single input (eg: discord) and sets default source, setup for 2 mic’s.
pactl load-module module-remap-source master=alsa_input.usb-Allen_Heath_Ltd_CQ18T-00.pro-input-0 source_name=remappedmic0 source_properties=“device.description=‘RemappedMic_Aux0’” remix=no master_channel_map=aux0 channel_map=aux0 channels=1
pactl load-module module-remap-source master=alsa_input.usb-Allen_Heath_Ltd_CQ18T-00.pro-input-0 source_name=remappedmic1 source_properties=“device.description=‘RemappedMic_Aux1’” remix=no master_channel_map=aux1 channel_map=aux0 channels=1
create a virtual sink of 18+19 as a single stereo output
pactl load-module module-remap-sink master=alsa_output.usb-Allen_Heath_Ltd_CQ18T-00.pro-output-0 sink_name=cq18t_usb_out sink_properties=“device.description=‘CQ18T_USB_Out’” remix=no master_channel_map=aux18,aux19 channel_map=aux0,aux1 channels=2 rate=96000
sometimes I have to manually connect this output to the 18/19 in raysession because it looses connection (i turn off and on the cq18 when i go to bed since there is no screensaver and i dont want it on the lcd to get any ghosting/burnin).
it wont let me attach image or link to image i get some spam garbage.
I am glad to see this post. I just open my new CQ - 12T and it is not recognized on my Ubuntu 24.04. So, I need to do some investigation. If you got it working, the USB input/output, then it must be possible for me. I will report back
Update: I switched from a USB Type A (on the CQ 12T) to USB C (into Ubuntu), which was not working, to a USB Type B (on the CQ 12T) to USB C (into Ubuntu) and the CQ was recognized, including all of the channels in Ardour! I tried several cables that I know are okay, and the USB Type A interface is just not working. I will put a ticket into Allen-Heath. Thanks again, whew!
Allen & Heath reply back to my query quickly:
Part of the issue is the use of the USB-A port.
The ports on our mixers respect the USB spec:
USB-B for device client (the CQ) to host (a computer) relationships,
and USB-A for device client (a storage device like a memory stick)
to host (the CQ) relationships.
Connecting the A port to a computer will never work,
as the CQ is expecting a storage device.
So, this makes sense. I’m okay with using USB-B. I’d say problem solved.
P.S: its good to see that they are respecting the USB spec, which I didn’t know about : )
Which is explained (again) by this: claude.ai explanation
