CQ 18T - USB B - Routing for streaming
Hello,
I would like to send an audio feed for stream and visio calls (Teams, Facetime).
I connect the CQ to MacBook via USB B. In some software, I can find IN and OUT via USB.
How can I choose a specific output for YouTube, Teams or other streaming/video media ?
Thanks for your advice.
Yohan
Not 100% sure what you mean here but in case you mean you want to stream a specific channel: Set channel 23/24 to the channel you’d like to be the main ouput for the stereo L/R channel:
You can also set the Stream Mode to Multitrack, then you can choose in the software any channel you’d like.
See also page 70 and 71 of the manual.
Thanks for your time and advise.
My concern is about the settings when it’s in multitrack.
In a DAW, you can select a specific USB chanel.
I’d like to know if it’s possible to do the same with some video communication softswear like Zoom, Teams, Facetime, Google Meet and some streaming.
I also tested with YouTube. It seems I can not select a specific USB channel for the streaming.
You can also try to set the CQ in stereo mode and select a specific output as the main Stereo L/R. This way you don’t have to configure anything in the streaming software as it will default use the track(s) you selected there:
