“Hi, I control a few A&H desks from my own iPad app over MIDI (scenes, mutes, levels with
‘get’ read-back). The CQ MIDI protocol document (V1.6.3) has no EQ parameters. I asked the
same question for SQ here: [LINK]. Is channel EQ available from third-party apps on CQ,
and is there any documentation? Thanks!”
Yes all EQ parameters are available via TCP.
I understand that you want to implement it inside your Stemly app.
To read TCP frame, I use Wireshark on a PC where the CQ is connected and I run CQMixpad app.
Set Wireshark to read your ethernet connection with the CQ and add this filter:
tcp.len >= 8 && tcp.len <= 18
Then move the control on the CQMixpad app to get the TCP frame out.
Test them with PacketSender (app for PC).
Thanks a lot, that’s exactly the pointer I was missing!
I’ll try the Wireshark + MixPad approach on my own desk and test the frames with PacketSender.
One more question, if you don’t mind: have you (or anyone here) tried the same method on the SQ series with SQ MixPad? I’d like to know if the EQ frames use the same format as on the CQ, or if the SQ differs.
Also, does the frame format stay the same between firmware versions, or has it changed in the past?
Thanks again for sharing this!
I cannot be 100 pc affirmative but I am pretty sure they are the same alongside A&H mixer’s range.
The TCP protocol for A&H mixers is proprietary, it’s not officially published but also can be modified at any new firmware.
Pls note also that the filter tcp.len >= 8 && tcp.len <= 18
might be too aggressive for some functions, for example it does not send back anything for color changes.
But it works for the main function.
Ok I finally got it for the fader colors.
You can try this new filter in Wireshark:
tcp.port == 51326 and tcp.len != 61 and tcp.len != 125 and tcp.len != 0
