CQ Recording from a single Aux Output
Is there any way on the CQ18T to make a recording to USB from a single Aux Sent.
By Default, the USB stereo record is taken from the main LR mix. It does look like this can be changed to record stereo from Aux sent pairs - 1/2, 3/4 & 5/6. This takes up two mixes. Unfortunately I only have one mix available to me as the others are used so was hoping that one mono mix could be recorded - maybe across both sides of the stereo recording.
Any thoughts?
You should actually be able to activate and record your individual Aux mix (Out 3 in the picture) in multitrack mode, but unfortunately this probably only works on SD.
But wouldn’t that be an alternative?
Thank you. SD recording is an option so I will look into this. I appreciate your time in responding.
