Does the CQ allow recording a multitrack to an SD card and separate stereo mix to a USB stick simultaneously? What size USB stick is required for a 3 hour show?
Thanks, Jon
Thanks, Jon
It isn’t possible to record multitrack and a stereo recording at the same time, unless you record via USB B to a computer.
A 2 or 4gb stick should be fine for that length of recording.
If I may correct that slightly: 2GB wouldn’t be enough for a 3-hour stereo recording, in my opinion.
You would need a 4GB USB stick - assuming 48kHz is sufficient for you.
Thanks very much for the help!
