I’m guessing I can’t do this, but worth at least asking.
I run Ableton Live on my PC. I currently have a Focusrite interface. From that interface I can map individual inputs in Ableton (1-8)
I’d love to do this with my CQ18T and I had a sneaky suspicion I could but I’m thinking maybe not.
I can “see” the CQ18T in Ableton, but I only have 1 and 2 for INPUTS. I was “hoping” I would see 1-16 and could map them to separate tracks in Ableton (multi-track record into my DAW?)
If that’s not possible can someone elaborate on what I “can” do with the CQ18T as it relates to my Ableton. I have it plugged in using USB-B
You’re very close indeed!
With the USB stereo channel in the CQ as a complete channel - go to the preamp section.
In here you will see noted the USB channels currently feeding that channel (should be 19/20 for the CQ-18T).
Send your Ableton output to these channels.
You can then process/monitor/mix this channel as with any other input.
