CQ18T: enable usb input 21/22 as extra USB track
on the CQ18T as there’s no ST2 input the usb output 21/22 are not assigned.
but the tracks are available via USB
Add another USB Track in place of ST2 and allow us to use it on CQ18 as an extra track via USB
Interesting. +1
+1 this would be useful for backing tracks and studio use of its not too complicated.
Isn’t the USB just a bus?
In Multi channel mode if I connect via USB to my computer I can route any of the 24 tracks on the CQ20 as I wish. So ST17 and 18 can be mono inputs if I choose. 21/22 usually assigned to USB can be directed as I wish also. Or am I misreading or not understanding the objective (Ie is this a LIVE mode issue as opposed to a STUDIO Recording mode request).
David
In the Cq18t the track is present via USB but is missing in the mixer.
On the cq20 you can select it and set it to analog/usb as it has an extra stereo in
would be nice to have the track routed also on cq18 to have two extra sends from a DAW
I’ll explain better
I’m using the mixer in two situation where this could be useful:
  1. as a recording interface
  2. playing backing track live
    for recording I would like to have the full 16 channels available for recording but I need some sends from the DAW for monitor output
    For backing tracks is the same I am sending 5 stereo stems from a daw with drums bass/keys gtrs/backing vocals/extra and I would like to route them on the outputs without using analog channels
    There’s already the ‘limitation’ that I cannot split the USB/bluetooth and stereo tracks so I need in teory 6 stereo track to handle the 6 aux busses for monitoring
Please yes!!! I also would love to have this “separation” from the USB or SD card playback, before I had a Behringer XR12 and I had ALL my backing tracks in a USB which I just plugged and in the app I could send left channel to FOH and right channel to my aux send or viceverse, PLEAAAASEEE we need this feature A&H TEAM!!!
My CQ-18T shows up with 24 inputs in Linux; but inputs 21-24 are not usable as USB returns anywhere? I was hoping the (unused) BT stereo input could be used as an extra USB return, but alas …
It can be.
You can find all the details on the USB routing here on this “secret” page:
https://support.allen-heath.com/hc/en-gb/articles/31464715078929-CQ-USB-B-Routing
You have four stereo returns available.
When I route audio from my PC to input 23/24, I don’t get any signal in the BT input. Is there a setting I’m missing, or can anybody actually confirm you can use 23/24 as stereo return from their PC to the CT18T?
UPDATE: Found it!
I had to use the CQ app on my phone to be able to edit the BT channel settings; it’s not available through the CQ-18T itself. I just selected the BT channel, and switched over to the config tab where I could set the source, and name. I don’t know which source I’ve selected, because that doesn’t fit on my screen :wink:
I was also able to rename the USB channel this way.
