CQ18t - how to playback channels 17-24?
ok, apologies in advance as I know it’s user error and i’m missing something obvious - but how do you playback multitrack recordings from channels 17-24?
Ch’s 1-16 are easy, go to config-inputs, set them to digital and press play on the recording. But I cant find any way to set channels 17-24 to be able to play (I can see that those channels have signals through the recording screen when I hit play - but can’t get that signal to play through speakers).
I’ve got channels 21/22 set to “st-in”, channels 23/24 set to “main l/r” and I want to be able to play those channels back at the same time as instruments from ch’s 1-16. (Also, i want to do it from the desk, as it’s just for recording quick practice on backing tracks to see how things sound, and I don;t want to have to go out to a DAW, but I want to be able to control ch levels so don;t want to do it from a straight stereo recording.)
Great question, I am having the same problem trying to play back a stereo recording assigned to ST#1 (Channels 17 & 18). The elapsed time count reflects 2:49 of recorded audio and the meters move when the play button is activated, however there is no audio available. (the lights are on but no one is at home) This is apparently a very different internal protocol than the ubiquitous USB A&H has previously offered and for those folks that have figured it out, a much better one.
The CQ is a no brainer for solo performers and a very vital element with many solo performers is deployment of BU tracks. The new SD card should be a perfect solution for easy soft button management of individual stereo BU tracks if we can figure out how to do it. At this point there is no clear detailed walk thru to achieve these ends with a CQ20b: unfortunately helpful AM&S teck return calls are now problematic.
Hugh
as far as i know, it’s possible to config stereo-in as ch17-18 same way like ch1-16.
what do you need MainLR and the outputs for?
If you play the digital inputs, the CQ’s processing produces all outputs and the MAIN, just like you record it bevor.
assuming you are running the same show or scene. Good if you had saved it.
Or record MainLR on USB as a stereo track if you want to hear only the summary.
Playing both at the same time makes no sense in my opinion.
Rx Thomas
Bueno chicos no sé si entendí bien la pregunta… pero si lo que quieren es reproducir los canales 17 a 24 en multitrack primero evidentemente es haberlos grabado… y esto sólo se puede hacer si lo hicieron a 48khz (en caso que los otros 16 tambien se quieran grabar evidentemente) ya que solo soporta 16 canales a 96khz, si no los canales del 17 al 24 les saldrá conun simbolo de admiración en un circulo rojo… entonces si lo hicieron bien es decir configuraron todo bien desde el inicio no habría problema al reproducir claro está esta señal va a salir por el fader de USB como una sóla mezcla lo que realmente sería incómodo ya que oir la mezcla de LR + todos los tracks por separado… pienso yo que fue diseñado para hacer post producción y como menciona Billb sólo para procesar en DAW o simplemente para oirlo en sólo… tengo unos cuantos videos sobre eso por si les sirve…lo único que mis videos están en español SALUDOS
I just bought a CQ18 and found myself struggling with the same problem. I found the key is in switching the inputs for those channels from Analogue to SD Card. For channels 1-16 this can be done through the config page, but for the higher channels you need to go through the processing page, find the channel you want and then click the gain control. This will open another screen where you change the input from analogue to SD. Hope this helps.
