Thanks for the suggestion, yes it’s a work around but not a fix. I expect the same operation as all other channels when assigning outputs to aux faders, if I have chosen POST FADER as an option in the Aux send then I expect a POST FADER placement of the input of that AUXILIARY not a PRE FADER placement if I choose the MAIN OUT CHANEL, this to me is a BUG as its misleading and it’s not giving me the needed result I want , which is , I need all outs to be a stereo main mix and all of them to be controlled by the ONE main mix fader , nothing tricky or unusual , it’s something some users want for different reasons.
Example, I might have a need to feed 5 zones or less of the main stereo mix and want simple level control over all of them on one fader , I am a solo artist and do my own mixing on stage and I want to monitor the main mix levels I want to hear in my in ears the level changes I make going to the front house etc etc.
I don’t like using DCAs as it unnecessarily complicates things if I need control of multiple faders I would rather use GROUP FADERS , DCAs are my last resort.
DCA faders don’t have metering , in my case this is important as I control everything while performing and I want to see levels instantly at all times, you can not insert an effect in to them to control the overall grouping, CQ18T has 8 channel faders on display by the time I place all my needed faders on screen so I can see all the relevant levels I am hogging up a space with DCAs that don’t give me much usefulness apart from volume control vithout visual feedback.
DCAs are not assignable to physical faders, this sucks big time and another reason for not using them.
All said, I prefer GROUP FADERS ANY DAY , and I expect to be able to create all AUX outputs to be PRE OR POST FADER NO MATTER WHERE THE SIGNAL COMES FROM.
DCAs are a cheap, simple workaround to give you volume only control of multiple faders nothing more.
That’s not my opinion, it’s a technical fact.
I’d rather have 2 group faders than 4DCAs on a mixer like this it would be a lot more useful to me.
Thanks again for the suggestion it might have to be the final solution due to lack of thought from designers.
