So I setup my CQ18t to use Studio One 5 DAW via USB cable. (BTW…exact same cable that I use with the xr-18.) I easily setup all 16 channels to work with Studio One; using CQ18t as audio interface. I arm the tracks and recorded multiple tracks simultaneously without any problem.
The Glitch? … appeared when I could not send audio back to the the CQ18t. Since I wanted to hear these tracks… I set the DAW as “Universal Thunderbolt” (for playback purposes.) The tracks did play back using UA; however, the CQ18t setting for all 16 tracks were truncated and would not record or recognize anything past 4 tracks. After numerous changes etc. I ended up shut everything down. When restarting I did not turn on the UA system and only then could I re- enter all 16 channels from the CQ18t. Even the saved template did not recognize these channels, until UA was not present.
Not sure if this is a “just my unit problem” or there are some compatibility issues? …but wanted to share my experiences. Thanks
