CQ20 multitrack recording channel not mapping right
Hello,
Somehow channels 17/18 aren’t showing in the multitrack recording page correctly. Instead of showing what’s plugged into channels 16/17, outputs 3 and 4 are showing as what’s being recorded. I’ve searched for a setting that might be causing this, but no luck. Any idea how to get channels 16/17 to show and not outputs 3 and 4?
I attached a pic showing 16/17 lists O3 and O4, which are outputs 3 and 4. Should be showing what’s plugged into channels 16/17 instead.
You can choose what channels are assigned for recording to 17/18 (and 19-24) on the Config->USB/SD/BT page. There’s a channel assignment section there, just change 17/18 to ST IN if that’s what you want to record.
Mark
Thanks so much, Mark! That was exactly it. The only place I didn’t look was there because seems an odd place for that parameter.
