CQ20B and iPhone 15 issues wifi connections
I am having an issue with the CQ20B. I have an iPad 8th gen with CQ mixpad that connects fine.
I have an iPhone with CQ For 4 (and mix station) this will join the CQ20 network, get the correct IP range yet when opening mixstation I get the error below also CQ 4 You doesn’t work either. Additionally this makes the iPad drop its connection.
Anyone else having issues with iPhone 15 iOS 26.5
I’m 2-3 feet away from CQ20
I figured this out. Turns out on the iPhone for Mix Station, and C 4 You needed the network toggle on. For each in iPhone > settings > apps > C 4 You > Local Network = ON (do same for mix station) might need to connect to cq20 network first then update the settings on iPhone. This FIXED my issue
