CQ4YOU Group "Me"
I have been able to assign names to the first three groups on the CQ4YOU App, but the name of group four is “Me” and I can’t change it. Anyone have a solution?
I’m afraid it’s not a solution, just an explanation!
The ME group is intended for your own signal only and that’s why it is not renamable.
CQ as entry level mixer should provide simple and easy to understand solutions.
You could add the feature request tag…
I appreciate it. I assume that each device that connects will have its own unique
“Me.”
You need to define the ME group contributions. Same as with the other groups.
This seems silly. “me” is different when I use the app as a guitarist, but when I want to let me drummer use the app to adjust his monitor, “me” shoud mean the drums.
ie, “me” should mean different things depending on which monitor send you are working on. as I see it now, you only get four groups period, not four groups per monitor send.
Can this be updated in future?
At least I don’t quite understand this time what you’re getting - probably because of my poor English.
But I’d say: You are completely free to configure your “Me” group however you like.
Typically, it would contain whatever you are producing yourself (instrument or/and vocal).
However, you could also assign it channels based on the question: What is most important for “Me”?
Every user of an Out mix should be able to configure their own four groups within their app in the way that makes the most sense for them.
Ah - it could be I have a better understanding now of what you mean.
But your CQ4You is just “4 You” (= personal monitoring) - and not to be passed around the band so that each musician can change their mixes one after another.
oh got it, maybe. does that mean each separate ios installation could have different groups?
Yes, each setup has to be independent, since every musician of course has their own personal monitoring - including their own “Me” group.
For a vocalist, it’s usually just their own one microphone, whereas a keyboardist with 4 instruments might want to mix 8 channels into their “Me”.
(And by the way, this also applies to installations on Android.)
gotcha. I didn’t understand that each iOS installation on separate devices would have their own independent groups :slight_smile:
The groups are done on the installation of the app. And the app remote controls the mixer, so corrections from the hardware or CQ MixPad are always possible.
It’s still a terrible decision by A&H to hardcode the “Me” label on one of the four user defined groups however. Just let people edit the name like the other three groups. If the user wants to name it “Me” they can, but there are lots of situations where “Me” isn’t appropriate.
It’s now a distant memory but I seem to remember that the Soundcraft Ui series call there app MoreMe and you personal mix it Me.
A&H are giving us the app so CQ4You with a Me channel makes more sense English.
