I am looking for a way to create and save a User Show template in Avantis that can be opened by other users but not overwritten. This way we can alway call up the “Basic Show settings” and save it as my own show without overwriting the default. I se there are some factory templates (FOH, Monitors, etc.) in the show list. But I would like to create my own with our system routing.
Unfortunately I don’t think it’s currently possible, but I would love to have that functionality.
Today I had to spend time undoing and accidental overwrite on one of my templates.
This seems to be something a lot of people are looking for.
An incorruptible Venue template, or templates for various show formats.
I am Head tech at a venue. We have 5 or 6 guys that use our Avantis and the events we do can be a single mic and PC input up to a 40 input band with 6 or 8 sends of foldback, FX and maybe delayed in-fills.
Ideally we’d have some templates for these shows with basic routing set-up to recall and start fresh, rather what some of my guys do which is open what-ever show was on last and rebuild from there, then spend an hour trying to figure out why a direct send to a an auxilliary or something is happening that someone set-up for some reason the day before and didn’t clear.
Just want to set up some Templates that aren’t able to be saved over or changed with meaningful names. HAving a Template option but not being able to use it the way we think we should is a bit frustrating.
I understand what you want to do but would giving each user their own profile and disabling Scene Edit do what you want? Setup/Config/User Profiles/Memories/Scene Edit. Or is that too big a hammer? I’m also guessing that if you simply locked the scene, they’d just blow right past that because there is no password protection for a locked scene.
As others have noted, there really isn’t a way to “lock” a show file currently. The only working solution I have is to save/backup the “template” show somewhere where you can use the backup to restore a the template show if it was to be accidentally overwritten.
The easiest way to do this is to store the template show like normal (perhaps user show slot #1), and save the same template show somewhere else in the show system - generally way down the list - like user show slot 490 or something - so that it is not easily found. This will help prevent a random person from accidentally overwriting the second “backup” copy of the template show.
If/when the regular template show (ie the show on slot #1) is accidentally overwritten, you can hopefully load the “backup” template show and then overwrite the “corrupt” template show file and bring it back to the desired condition.
Alternatively, you can also save the template show on a USB drive and remove it from the console, or save the show using a instance of the Avantis Director software (which will save the show file on the computer). This way there should always be a “clean” copy of the template show available in several locations that are removed from the console itself.
Hopefully all of that makes sense.
PS - it is good to train your operators to start the console, load the template show, and immediately savetheir own show file (using the appropriate date as part of the show title) - which they can then overwrite periodically to ensure their file is current. Doing this will help ensure they won’t overwrite the template show by accident. It also gets them into the habit of saving their own show files.
