CTI 1500 monitor mix solutions
Hey I have Cti 1500 and I’m looking to save a snap shot of a monitor mix during live performance. We have 3 piano players in rotation on two pianos. Every 30min one player goes on break and is replaced by the player coming off break. So both sides of the stage are used by all 3 piano players throughout the night.
My question is: how would I save a snap shot of a monitor mix so that I could bring up that mix in either monitor for any of the 3 piano players working that night?
We can also set up a tablet or two and maybe monitor mix from the stage if necessary. I’m looking for any and all solutions.
The new Mix channel Libraries in V2 can be filtered to recall ‘Routing’ only. This means you can store and recall different monitor mixes on different Auxes.
Where do I download the v2 mix libraries?
You don’t.
You make sure your console is on the latest firmware, and then you can create your own libraries of monitor mixes based on what NicB suggested.
The approach I would use is to have a matrix for each stage position, and a mix for each performer. You can send the performers mix to the correct matrix and they will get what they need. This also allows you to make EQ changes per position and per person at the same time.
Is there a link for how to create a matrix?
