Custom buttons:
after selecting play/pause, the function is assigned to only one specific song.
If another track is playing, the console throws an error
Custom buttons:
After selecting stop (play) - when pressed, playback will jump to the next track. Playback stops after skipping to the end of the playlist
What is the problem? This is just a description of a situation.
Please set the soft keys Play / Pause to stop and start each track. When setting the soft key, I have to select a song, and this button stops and starts only this particular track
I need to use Play / Pause on every track in the playlist that is currently playing.
So that the Play / Pause on soft keys work the same as the Play / Pause button in the player on the touch monitor
