Custom colors for Softkeys
Before 2.0, I had a softkey set to a mute group containing the vocal FX sends. It worked great and did everything I wanted, until we started inserting stuff on some vocal channels. No big deal, I created some actions to both mute the relevant FX sends and bypass the FX and it works perfectly, but now instead of “off” and “red”, the softkey is “sky blue” and “purple”. This is obviously not the end of the world, but functionally speaking it’s still a mute button and it’d be nice if it had the mute button colors.
There are some other actions I have setup that similar in that instead of toggling between two “equally valid” states, are used to switch some channels between input A and input B in the event of a wireless failure… I’d rather have the button be off in the “input a” state and white or whatever in the “input b” state so that it’s more obvious that something’s up.
Anyway, it’d be nice if we could color-code the softkeys in a way that makes sense with how they’re being used and how the user thinks as opposed to what kind of option they’re set to.
Great feature suggestion. Actions should definitely have the ability to colour code the user key to the users preference as well as to make it flash or toggle.
Agreed, I use a Soft key to toggle between two actions and it would be nice to choose the color between the two actions…
would be even nicer to have the toggle function in the action itself to be able to create a series of action with different colours self assigned (eg: more than two actions toggled as a loop every time we fire the action)
