We’ve just released Custom Control, a customizable, cross-platform control app, providing bespoke control over Allen & Heath dLive installed audio systems.
Have a look here for more information, videos, and links to the apps and editor: https://www.allen-heath.com/custom-control/
Interesting!
Could that be used for the still missed musician monitor control app? Have to look into it…
Noice!
Really interested in checking this out for the mobile phone app
Already tested it.
Quite some programming but very flexible. Build your own monitor app!
You could indeed build a personal monitoring app. Multiple layouts (e.g. controlling different Aux mixes) can coexist in the same config file, assigned to different user profiles. So for example User 1 controls Aux 1 etc.
iOS app not available in Norway? Cant find it in App Store…
Very Cool! This is exactly what I’ve been doing with Touch OSC since the dLive was released. …only better!
I’m already working on several layouts for a few different applications. I noticed a bug with Mains fader though: It doesn’t look like it actually controls the mains fader. Did I miss something?
One other thing I would love to see in the next revision, especially as this is geared toward the installation market: is the ability to limit output values for faders. I do this in Touch OSC for instance, to only allow “unskilled,” users to move a fader from -inf to a maximum of 0dB for the entire fader throw. It prevents all kinds of issues in most environments where things need to be relatively dummy resistant.
One other thing that would be useful is a shortcut enable/disable setting for faders so that you could, say, double-tap to set a fader to 0. (…maybe triple tap as an extra precaution?)
Does the configuration live in the mix rack or the device?
Yeah, the layouts are stored in console, which is pretty cool. It makes sense from an administrative perspective, and I would imagine that saves from having the blowouts you sometimes see with MixPad. (Layouts just get completely messed up every once in a while, it’s an open ticket w/ support.) You just have to build the layouts, then push them to the console from the editor.
I also like that you can assign specific layouts for specific user logins, although it means application is limited for use as an IEM controller due to the limited number of logins available.
Set the Audio Taper of a fader object to Off, and the Min Gain / Max Gain properties will be displayed.
What is the limit?
@ Nikola, thanks! That’s exactly what I needed. It didn’t occur to me the fader setup was identical to ip8. duh.
@ Mr X - 10 user logins per console.
Remember you can also have different interfaces serving the same user profile, depending on the device type. E.g. user ‘AV guy’ can have a couple of faders or preset recalls on a phone, some more control on a tablet, and more comprehensive routing and metering on a desktop machine. Although this doesn’t help with the personal monitoring application discussed above, it’s a great feature to have in installations.
You can even create Scene to Layout dependencies. Basically have interfaces which are only displayed when a specific Scene (or selection of Scenes) is displayed.
…okay one more thing I’d like to see here in future updates: Double tap (or triple) tap option to return knobs to center (Pan, specifically.)
…aaaand one more bug: GR meter, Does not appear to work for Stereo auxes, but does for inputs.
Also, for what it’s worth, I realized I do have enough logins available to make this a viable option for IEM iPads for our site; band loves it so far! Really an improvement on a number of levels as opposed to running MixPad.
many thanks to you for this solution!
I immediately built myself a small page that allows me to control the levels of the background feeds without having to go to the mixer or use an iPad. Just on the phone, just like the small iPhone app of the iLive… great!
Which I didn’t quite understand:
I prepared a few pages offline and then transferred them to the console. But here the channel assignments somehow didn’t work. Then I quickly made a new page, so it worked immediately.
I can’t explain that to myself.
This is pretty awesome. Hopefully it can be expanded in the future to include all the control functions - eq, comp/gate, effect parameters, etc.
Sent from my iPhone using Tapatalk Pro
Is there any particular reason why I cant seem to get Stereo Aux’s or Matrix’s to work?
I have tried several times on Mac & PC editor, and everytime it shows as unavailable.
I am running a DM32 & C3500. I have a config of 2-StGroups / 6-MonoFX / 2-MonoAux / 14-StAux / 6-MonoMtx / 2-StMtx / 1-PFL.
Trying to set up as Sends on Faders for St.Aux 14
Thanks for any help
