Custom layer
It would be nice with at last one customazible layer
Not to sound like a broken record (or a shill for Mixing Station), but while you wait to see if this feature is ever added, you can use the third party app “Mixing Station” with CQ right now. One of it’s many great features is that you can create your own custom layers. It also allows for unlimited DCA groups (called iDCA in MS) which is another “much requested” feature of the CQ series.
Hi, i familier with mixing station, so that will work for meg. Thanks. But can you use the touch screen on the mixer with quick channelse and the a&h software on the mixer samotanius with ms on an ipad on the side?
Indeed, at least one customisable layer for post setup/sound check, live gig adjustments would be useful mainly for vocal tweaks and if any possiblility of vca controls or grouping of say drums and backline, gives you a window for easy adjustments while also being the keys player tooin small band format
maybe also the option to disable unused channels.
Or make it possible to assign a fader/channel to ‘selection’. Then you could have a full-track/channel-view and a quick view, with the most important.
Yes, a custom layer (or more) is essential. Mixing Station is great but I can’t access recording functions from it (although I set up a footswitch for start/stop recording)
+1
Custom Layers as in QU where you can combine inputs , outputs , Audio player etc, please.
It must be possible to combine everything you need on one Layer. "make Tablet life easier "
  • 1,000,000.
    CQ20
+10000
if i use only mixing station i could have stayed with the behringer xr-18
