Hi developpers,
here is a list of ideas I made these last couple of year. I removed a bunch of features that appeared in the updates over this time… thank a lot for your Wonderfull work it’s such a pleasure to work with the Dlive desks. sound and soft is really good !
Here is just some ideas from an humble sound engineer.
Sorry if some features are redundant with other topics or already there in lasts firmwares.
Time Code
- I reacted to a post about that. This would be a game changer compare to other brands to be able to assign an input for a LTC or take MTC from network to automate Scene go, Actions, presets recalling,… even more… automations.
Multi surface :
- I/O section : View local I/O from other surfaces making enable patching
- Enable use of the I/O port on all surfaces when on multi surface mode
D-Live director :
- Time clock update from DLive director using computer time & date (“auto update on online sync” Check box ?)
Talkback Section :
- Separate trim by talk groups
- channel direct out in the Input possibilities
Mix Busses :
- Follow pan to stereo mixes separately by inputs
- Trim on the input signal of mix busses/groups/FX send busses/Matrixes
Scenes and shows :
- move/copy/paste options
- Surface offline mode
I/O cards
- Enable Gain control and gain compensation of preamps thru Madi/Dante card
I/O section :
- Clear patch option (by page and a full clear patch option)
Surface pref :
- Strip assign section : Copy/paste/Move/Swap/Clear functions on banks
- When assigning Gate threshold on custom rotary functions, it doesn’t show with the “source expender”
- When viewing meters on the screen’s bottom, touching a meter would select this channel
MixRack Prefs :
- Global set default option (eg. Set all Mixes to Mute/unmute, in Fader to 0/-inf, etc…) This is a very useful option on Digico.
- Stereo pair of channel be direct without reconfiguring the desk and save/recalled in scenes
- Possibility of splitting the gain, trim and delay on left/right of stereo a channel
Free Assignations of the 6 rotaries next on the right of the screens :
- Fully customisable assignation of the rotaries (so you can set for eg : a chan’s FX send, an FX parameter, the led strip dimmer,… on the same page).
FX :
- Stereo Tap Delay : problem when sending in stereo fx mix, when panning source send to the left, there is no feedback (delay 1 time to the left, no repetitions) and when panning right the feedback is mono (delay 1 time to the right and repetitions to the center)
Hardware :
- A DX Module same as DX012 but with inputs (4 Analog inputs and 8 Analog/AES inputs). Or a DX024 (with 12 XLR in and 12 out with same analog/AES options
